How To: Megasquirt Your 1st Gen Probe/MX6 Turbo - Page 5 - Mazda MX-6 Forum
post #61 of 70 (permalink) Old 4-27-10, 16:42
you're not missing a step. The BP igniters are better and have one less wire to contend with. Yes, the coil is driven from the igniter wiring
Gotcha so I have to undo the coil driver to use the igniter instead correct?
typeo_n3g is offline
post #62 of 70 (permalink) Old 4-27-10, 17:12
Zach's Avatar
Quoted: 7 Post(s)
Yes. do not use the drivers within MS, they will get too hot
2008 Legacy GT Spec.B - Quartz Silver Metallic | Not Stock
Zach is offline
post #63 of 70 (permalink) Old 4-28-10, 8:51
Matt Cramer's Avatar
Quoted: 1 Post(s)
We've come out with new coil drivers in the past 2 years that don't have overheating issues, but usually we prefer to use as much stock wiring as possible anyway.
Matt Cramer
DIYAutoTune.com - Megasquirt, fuel injectors, wideband O2 sensors, and more
Matt Cramer is offline
post #64 of 70 (permalink) Old 5-4-10, 12:04
Just as a side note. after using this write up and a few mods to fire the igniter car started right up. This is an awesome write-up!!
post #65 of 70 (permalink) Old 12-13-11, 10:10 Thread Starter
d0zxmustang's Avatar
That's awesome to hear, I always wondered if anyone else other than me actually has tried it. Great to hear it was a big help!
d0zxmustang is offline
post #66 of 70 (permalink) Old 12-13-11, 14:19
Yeah the car has been running on it since. I've blown engines with my bad tuning and lifted heads but the MS unit is rock solid. I'm now running 23ish PSi on an N/A block and a 57Trim T3/T04E. it's all torque steer all the time. lol
post #67 of 70 (permalink) Old 5-14-12, 8:27
some of the stuff in the write up is inconsistent with the pin out. for example the fuel injectors for the write up is a different than where the ms write up suggest and this is als the case with the fuel pump.
Ebonick22 is offline
post #68 of 70 (permalink) Old 9-11-13, 21:23
This may be a stupid question but obviously you know what you are doing when it comes to this so here it comes... Can this write up be applied to a fe3 using the f2t harness?
MTRCR MX-6 is offline
post #69 of 70 (permalink) Old 8-4-19, 10:52
Quoted: 1 Post(s)
Power: 0
ignition settings
I know its an old thread but if anyone who made this work I would like to know your ignition options/wheel decoder settings, mainly the trigger position settings and trigger angle.
My setup is in a b2200 which I have run off stock f2t ecu setup for years and would like to upgrade to megasquirt 1 cpu with board ver. 3.
I also have a N/A b2200 with 12 valve head running ms1 fuel only just for fun!
brad510 is offline
post #70 of 70 (permalink) Old 8-6-19, 9:45
DarkMx-6's Avatar
Quoted: 97 Post(s)
Garage
You'll have to make a thread about your trucks I would love to see it.
Free bump for your MS
Mx-7 Project reborn! -F2T in a FC RX-7 (400hp?)
DarkMx-6 is offline
