KL into 89PGT - Page 8 - Mazda MX-6 Forum
 1Likes
post #106 of 138 (permalink) Old 5-27-10, 0:39 Thread Starter
BlueInfinity48's Avatar
Get a Turbo Manual mount...it should line up perfectly. The Auto's are offset to the rear a bit
I need the engine to come back on the passenger side. The engine sits crooked, so if the engine meets up with the mount I'm using, the engine would sit perfectly
1989 Ford Probe GT
OBDII-A/C-Heater-Factory Keyless-MAF Conversion
KL'd and BOOSTED
BlueInfinity48 is offline
post #107 of 138 (permalink) Old 5-30-10, 12:53 Thread Starter
this thing should be done in a week or so
1989 Ford Probe GT
KL'd and BOOSTED
post #108 of 138 (permalink) Old 5-30-10, 13:12
sweeet man after its done you should get some track numbers for it just we can all see weather its worth it or not
89lxmorepower is offline
post #109 of 138 (permalink) Old 5-30-10, 13:29 Thread Starter
Most definately
1989 Ford Probe GT
KL'd and BOOSTED
post #110 of 138 (permalink) Old 6-4-10, 0:38 Thread Starter
It's time
OK guys the end has come. The mounts are in place. The shifter stablizer was lengthend the mount bracket were fabbed and the frame was notched for the drain plug. As soon as a get is back from the shop. Pics will be ASAP. All I need to do is put this baby under insurance and get stickers for it. Then is finished. After that the G4 mani and phenos are going on. Then MAF conversion. Also need spacers for the rear FD's. Then mounts being used are 1G N/A mount a 1G N/A rear mount a 2nd gen front and driver side mount
1989 Ford Probe GT
KL'd and BOOSTED
post #111 of 138 (permalink) Old 6-4-10, 8:14
Fastest95PGT's Avatar
Quoted: 13 Post(s)
So did you end up using a 1g GT passenger side upper mount?
Pic of this mount completed would help your thread content.
PARTING A LOT OF 2g and 1g STUFF
FS: Borla for sale.
FS: Clear headlight covers, headlight, fog, tail, gauge cluster
90 PGT MTX with 97k original miles!
Fastest95PGT is offline
post #112 of 138 (permalink) Old 6-4-10, 10:06
lundgren420's Avatar
Quoted: 1 Post(s)
I suggest that you make a full write up later and expalne how to do this swap for further reference. I would like to see this swap done on a 1st gen MX6 as well. Keep up the hard work and you will reap the benifits of a 200 hp N/A beast. BTW what is the gross weight difference between the first and second gen?
1988 MX6 https://www.mx6.com/forums/showthread...ferrerid=35300
lundgren420 is offline
post #113 of 138 (permalink) Old 6-4-10, 11:38 Thread Starter
I used a 91 MX6 N/A ATX upper pass. mount. I'll post pictures when i have the car at my house which should be at around 10pm or so. The mount brackets were fabbed up. The shifter stab. was lengthened also.
1989 Ford Probe GT
KL'd and BOOSTED
post #114 of 138 (permalink) Old 6-4-10, 11:53 Thread Starter
The gross on my 91 MX6 N/A ATX is 3750 on my 96 PGT MTX is 3792. Not much. The curb weight on a 89PGT is 2870 on a 96PGT it's 2921. The weight difference isn't much at all, but with my weight reduction it should be.
No A/C or P/S
ABS delete
rear wiper delete
Manual rack
Spare tire well delete.
Heater core, evaporator, vents, a/c controls gone
Slim fans
FD's
i have full interior though.
any misc brackets and bolts that weren't needed.
the 1g doesn't have all of that airbag stuff.
We will see I will be racing my friends 2g with cold air intake and exhaust
I will have PS headers with straight pipe(for now until I can get a resonator and muffler) and a cone filter.
I had weighed my car at the track w/ the F2T and before all of this weight reduction and it weighed in at 2807.
1989 Ford Probe GT
KL'd and BOOSTED
post #115 of 138 (permalink) Old 6-4-10, 14:36
dude that thing is gonna fly it looks really great so far and i cant believe mx 6 s weigh more than probes i always thought it was the other way around
post #116 of 138 (permalink) Old 6-4-10, 15:34
Zach's Avatar
Quoted: 9 Post(s)
gross and curb weight are different. Get on a scale to get a real reading
Gavin weighed his MX6 GT at 2600 something pounds I believe.
2008 Legacy GT Spec.B - Quartz Silver Metallic | Not Stock
Zach is offline
post #117 of 138 (permalink) Old 6-4-10, 17:03 Thread Starter
we will see gonna pick up the car tonight. oh man can't wait
1989 Ford Probe GT
KL'd and BOOSTED
post #118 of 138 (permalink) Old 6-5-10, 0:38 Thread Starter
Car needs an alignment bad! I need a burp tank. new brake booster and master cylinder. need probably a slave cylinder for the clutch too. NEEDS muffler. its running PS headers no cat and a resonator. I don't know if it just me, but the car feels REALLY slow. I hope its because there is no backpressure. or just because i'm driving a 1g and think it should be faster. we will see when i fix everything. i'll feel better. or maybe something happened to the motor in the wreck.
1989 Ford Probe GT
KL'd and BOOSTED
post #119 of 138 (permalink) Old 6-5-10, 1:29
Quoted: 1 Post(s)
horseshit...why would any pump want backpressure? Too big of piping maybe...but not too likely, the kl breathes pretty good. My buddy used to run a 3" on his N/A due to free parts and he liked the sound, and had the fastest one in the valley for a long time, with mostly simple bolt ons...anytime I do a project, I'm always disappointed the first time I drive it, too.
We tried driving his aorund with no exhasut for a couple days, hard as hell to keep quiet...we would turn it off as we passed the sheriff's house and coast...
matt89glturbo is offline
post #120 of 138 (permalink) Old 6-5-10, 1:42 Thread Starter
Well shit. it is 2.5". the car is REALLY slow though maybe because its really loud and doesn't move
1989 Ford Probe GT
KL'd and BOOSTED
