IAC gasket & injector seals - Mazda MX-6 Forum
post #1 of 11 (permalink) Old 2-22-12, 13:45 Thread Starter
Anybody between Seattle and Blaine know where I can find these gaskets? I need the injector o ring between the fuel rail and intake and a IAC gasket, which here in Vancouver BC, seems the only option is to buy from dealer but I make semi frequent trips to Seattle so I wouldn't mind knowing a place that would have them for sure. I checked napa and some other place that was a Uni-select place, who checked with world PAC (which I work for) who doesn't stock either of them.
bsb2001ca is offline
post #2 of 11 (permalink) Old 2-22-12, 20:43
I could not find these injector seals anywhere, and I needed to get my car running asap....I ended up using the originals again. Call a dealer and ask them.
unamedplaya87 is offline
post #3 of 11 (permalink) Old 2-22-12, 21:38 Thread Starter
Dealer wants almost 17 each for the seals, and 132 for the IAC gasket.
post #4 of 11 (permalink) Old 2-27-12, 7:01
PaulG's Avatar
Quoted: 26 Post(s)
Power: 6
prdonline carries the injector o-rings, I don't know if they're a good vendor or not, just stating where I saw them.
Viton Injector O-Ring Set, PRD Online
1997 MX-6 LS
PaulG is offline
post #5 of 11 (permalink) Old 2-28-12, 13:12
djdevon3's Avatar
Quoted: 2 Post(s)
Garage
You can quickly, easily, and cheaply make your own IAC gasket. Probably cost me $5 to make 1. With a sheet you could probably make about 5-10 of them no problem.
Iac (Idle Air Control) & Throttle Body Cleaning (1993-2002 I4) - Mazda626 Forums
djdevon3 is offline
post #6 of 11 (permalink) Old 2-29-12, 5:29
PaulG's Avatar
Quoted: 26 Post(s)
Power: 6
If I remember correctly, the v6 iac has a channel for the gasket to sit in, it's not two flat mating surfaces.
Edit: It looks like the channel is on the tb side: https://www.mx6.com/forums/587764-post6.html
1997 MX-6 LS
PaulG is offline
post #7 of 11 (permalink) Old 2-29-12, 20:47
djdevon3's Avatar
Quoted: 2 Post(s)
Garage
Oh that's really neat to see, thanks PaulG. Hmmm the 3rd image there shows where the rubber seal was removed and the mating surfaced machined flat. That might be something to consider.
djdevon3 is offline
post #8 of 11 (permalink) Old 2-29-12, 21:09
They were not machined flat, the rubber seal groove is on the TB, not the IAC!
poissonn is offline
post #9 of 11 (permalink) Old 3-19-12, 1:22 Thread Starter
Can either of these seals be reused? I'm asking cause the IAC is no good and isnt being replaced cause its leaking, and same with the injector seals.
post #10 of 11 (permalink) Old 3-19-12, 1:23 Thread Starter
Rock auto doesn't seem to have the part for the V6, 2.5L. Most website that carry it doesn't ship to Canada.
post #11 of 11 (permalink) Old 3-27-12, 16:08
djdevon3's Avatar
Quoted: 2 Post(s)
Garage
If the MX-6 IAC is going to have a problem with longevity due to those seals you guys might want to figure out a tutorial for machine them down, inserting a fiber gasket, and drilling the ports back to match up. Might not be a bad way to go otherwise you're going to have to continually replace the whole thing over stupid little seals. As you can see from the image above the 626 doesn't have that issue and is a breeze to replace. Just food for thought.
djdevon3 is offline
