Hi all,
I'm new here, just bought my MX6 in June for $500 in driveable, if not excelllent condition. It's been sitting in my storage unit since then, haven't had time to mess with it until recently.
Last night I impulse bought a set of base 17" 350z rims for $75 (my daily driver is a 300zx) and was wondering if anyone had experience installing these rims on a 2G MX6 or knows anything about the necessary spacing or tires.
I haven't really had much experience working on cars but I bought my MX6 to change that :) any help or advice is appreciated. Thanks!
And this:
According to rim manufacturers declarations, the following rims should fit Mazda MX-6 2gen Coupe (GE) (1992-1997):
Rim size:6.5 J x 16
Bolt pattern:5 x 114.3 mm
Hub centerbore:67 mm
Offset: ET = 50 mm
Rim type:steel
specs interline
Rim size: 5.5 J x 14
Bolt pattern: 5 x 114.3 mm
Hub centerbore: 67 mm
Offset: ET = 45 mm
Rim type: steel
base models
specs interline
Rim size: 7 J x 15 H2
Offset: ET = 30 mm
Rim type: alloy
specs interline
Rim size: 7.5 J x 16 H2
Offset: ET = 30 mm
Rim type: alloy
specs interline
Rim size: 7.5 J x 17 H2
Offset: ET = 30 mm
Rim type: alloy
specs interline
Rim size:8 J x 17 H2
Offset: ET = 30 mm
Rim type:alloy
