Welcome to the board!
Is the check engine light on?
Here's how to read the codes, to diagnose the check engine light: 1993-1995 Engine Controller Malfunction Codes (get a paper clip, and use it to connect the 'ten' and 'gnd' pins in the diagnostic box next to the battery, then turn the key to 'on' and watch the cel flash). I would do this even if the check engine light is not on.
When it warms up, it should idle at around 650 rpm. Is it just a very low idle rpm, or does it idel rough even at around 650rpm? If the former, maybe it just needs the idle raised (big Phillips screw on the top of the throttle body, turn it counterclockwise to raise the idle).
