I recently purchased a 1996 MX6 V6 manual transmission and I am experiencing EGR/idle issues. Since I am new to the car, I am hoping someone can help point me in the right direction.
I bought the car non-running due to a charging issue. Once I sorted that out the car ran fine for a couple months until I started experiencing coolant leaks and idle issues. Over a short period of time I had the following issues in the following order:
1. Hard starting when cold (I think this is unrelated - maybe FPR or fuel pump)
2. Intermittent rough/low idle
3. Coolant leak from back of engine evident when vehicle is shut off (drips onto exhaust/ground)
When I noticed the coolant leak I decided it was time to investigate. I could not see many sources for coolant behind the engine so I replaced the heater core hoses and the hoses to the EGR hoping that would resolve the issue. After the repair the idle was worse, the coolant leak was still present, and I started getting a P1402 error code (EGR Valve Position Sensor Circuit). When investigating the code I noticed that a previous owner had damaged the EGR position sensor connector and made a jumper using random wire and unprotected spade connectors. I tried cleaning the connections but it did not help. I attempted to remove the EGR but it is extremely difficult to access so I decided to abort since I assumed my issues were with the wiring. I got an EGR pigtail/connector from the junkyard from a Miata and bought a replacement EGR. I figured I would start with just swapping the sensor and repairing the wiring. Unfortunately, this did not fix the problem - in fact the idle is even worse, I'm getting an intermittent misfire code (P0300) and the vehicle shudders and runs poorly below 3500 rpm now.
I figure at this point I should bite the bullet and remove the EGR and inspect/replace. My concern is that previous owners have been messing around reeking havoc in this car (wiring issue above, loose intake/throttle body bolts, loose/stripped valve cover bolts, snapped bolts on the intake that control the baffle doors that I assume are part of the EGR). Basically, I don't want to go through the immense hassle of replacing the EGR if there are other diagnostic approaches I should take. Does this sound like a cut-and-dry EGR issue?
Also, maybe unrelated, but there appears to be a block-off plate on the back of the engine near the EGR but more on the passenger side of the car (I can barely see it). Does anyone know if this is stock or is this another gift from the previous owner?
It's a shame that the engine is so molested because the car is an M-edition with low mileage and a very nice interior and exterior. It ran very strong before these issues and still pulls hard above 3500 rpm. I'd keep digging on my own but every time I touch the car it seems to just get worse/develop new issues.
Thank you for your help.
