141 - 160 of 190 Posts
another addition for compatible dual piston calipers using the stock caliper brackets are all trac 2nd gen toyota celica calipers
Does anyone know, if the first gen springs and strut mount, fit the 2nd gen strut ?
I already know about the 2nd gen shock, spring with 1st gen strut mount.
Ok I called ARP and gave them the messurements for the head bolts holes. Head thinkness 76mm, block bolts depth 29mm and the tread Pitch 12 by 1.50
ARP 2000
Part number# AU4.950-2B $20.22 US per stud
Washer part# 200-8516 (per washer) $.94
Nuts part# 300-8307 (per nut) $4.33
If anybody looking for ARP head bolts.
-Does anybody know for a fact that these are the right sizes. I'd hate to buy them and have them not work
the BS on this is that runs up to $250+ my buddy bought a set for his sr20 s13. 160 i think..
Really? That's interesting... 90-93 AllTracs had single piston calipers.
Bolt measurements are correct, but need to verify that indeed the Millenia and FD front strut mounts will work and become a new aftermarket for rear strut mounts for the 4ws :)
my mix up actually it would be 85-89 4th gen celica alltracs:angel:
[cough]
88-89
[/cough]
Some of the early JDM 90-91 Celica GT4s also had twin pots.
What's interesting in all this is that if the dual piston calipers, it should be just as hard/simple to fit the gigantic ST205 Celica GT4 brakes onto a 1G as it is on an ST165/ST185. They're heavy, but they're also gigantic.
[cough]
88-89
[/cough]
hush your mouth...I'm working on getting a bracket made for FC monoblock 4pot calipers to work
You're in no danger, really... The ST205 brakes require brackets to work on ST165/ST185 anyways, so same rule applies.
ST205 brakes are bigger than the FC units, though. ;)
They look pretty much the same size, same design even. Though the 205's look like cast iron/steel. The FC's are aluminum :)
The calipers might be the same, but the rotors are larger i think. Iono, been awhile since i messed with them since i realized that they were stupid overkill on my 2300lb Celica. :p
does anyone know if the 1995-96 mazda astina gt seats will fit our cars
Millenia front mounts won't work but late 90's Maxima's will :)
Dual valve springs
I can't believe nobody beat me to this:
What: Dual valve springs!
Donor car: GC 626 & B2000.
The OEM dual valve springs from a 2 litre SOHC Mazda FE as found in GC 626's and B2000 trucks.
Also aftermarket spring for the FE or nissan L series engines for even higher seat pressure.
Mods required: none these are a direct fit on an F2.
Well almost... You can fit them as is but it is better to also fit the FE spring seat (sits between the head and the spring) to protect the soft alloy of the head.
Why: The OEM F2 springs have much too low a seat pressure for a highly boosted small-medium size turbo engine.
This leads to valve bounce (the exhaust valve lifting off it's seat due to high exhaust manifold pressure) during the induction stoke when it's meant to be closed.
This kill torque production over around 4000 rpm with a small frame turbo once you are running over 20psi or so.
Note:- With a large frame turbo running the same 20psi exhaust manifold pressure is much less and valve bounce is greatly reduced, therefore dual valve springs are of less benefit in this case.
Interest, mine wouldn't fit unless I flipped it with the raised ends facing down. I tried each mount on both strut tops and wouldn't fit unless I flipped them.
So where are the actual stats that say what spring pressure the B2000 springs are vs the F2?
My estimate for seat pressure for FE-8V spring in a F2 can be found at post #38 in my valve springs thread.
The stock seat pressures for the F2 I'm sure you know are in the TD section of the WSM.
