Your options are:
-Konis...about $160 each, and you don't get an entire strut, you have to cut the inside out of your old ones and stick in the Koni cartridge. They are adjustable.
-Tokico...about $120 each, non-adjustable, stiffer than stock. Complete strut, fits in without a prob they say.
-KYB...about $65 each, non-adjustable, about the same as stock. Complete strut, fits in without a problem I know because I have them.
-Gabriel Auto-Adjust struts from AutoZONE. These replace your stock auto-adjust struts. I don't know anyone who has them or how good they are. They ARE gauranteed for life, but convincing the AutoZONE people that you need a free replacement (proving it to them) every time they wear out may get old.
-Put in 2nd generation struts. It has been said that 2nd gen. struts and springs will fit on the front, and in the rear also if you shave 1/16" off your rear spindle. You have to use both the 2nd gen. struts and springs though, and it will lower the car about an inch. This opens your options up because if you went this route you could use Tokico Illumina adjustables.
