1 - 17 of 17 Posts
Lower Price! now $600 SHIPPED
email me with interest/questions: [email protected]
Kit is built for a Turbonetics T3 turbo. I have the Turbonetics T3 super 60 .48 A/R (It needs to be rebuilt)
You need only to get your own oil lines and high flow fuel pump!
IC pipes are aluminum 2.5" with professional welds. B pipe and DP are 3" stainless. Bypass valve is Forge. Wastegate is generic w/ 4 psi spring. FMU is Blox 11:1.
I ran this kit with 9psi for one summer. has all bolts/washers/clamps/IC bracket/gaskets. You dont need injectors with this kit. The DP and B pipe bolt up to a catback exhaust nicely. I had a Greddy Evo. Everything fit beautifully.
i also found the air filter and turbo inlet tube to go with this, as well as the old oil lines if anyone wants to reuse them.
i have a 2.0 and i got the cash!! i live in bronston ky. ware did you get that manafold i have looked and looked for one? also how many pounds of boost can i push on factory internals ??? give me call 606 305 6104 ask for zack
its used, so the paint is burned and there is some oil residue, but its all professional welds and works efficiently. a very solid reliable kit. hard to find a similar kit with a matching down pipe and B-pipe set. You will not find anything as complete and easy. all the custom fab is done for you.
i want this but not at 600, if you lower the price please please let me know... and is it easy to install for one person? never done a turbo before?
i am interested :) i should have some cash soon for it we can talk about a price later though
1 - 17 of 17 Posts
