I've got a complete 1994 Mazda Shop Manual for the MX6. What's the problem you're having?JOHN said:The Haynes manual unfortunately does not contain sufficient
to help in solving ABS faults.
Mike 94PGT said:I've got a complete 1994 Mazda Shop Manual for the MX6. What's the problem you're having?JOHN said:The Haynes manual unfortunately does not contain sufficient
the problem is that the ABS failure light comes on and the system disengages.It can be reset by switching off the ignition and restaring the motor,but the fault reappears sometime later(could be 5minutes or 5 days).The ABS fault memory says code 11 & 12,which refers to both front wheel sensors being defective.This does not appear to be the case
and the problem is likely to be electronic or in the wiring.
I would like to obtain the ABS system block and wiring diagrams to trouble shoot.At this stage I dont even know where the ABS control box is?.
