Possible setup? just a quick drawing
I did think about turning of the input but i was thinking about kill switches that do it this way but i like the idea of turning off the input better. How much would be involved with the ECU just the Eprom or some other things, would i be able to have a setup to edit it myself and the big question the cost? If i could get a setup that i could tune aswell then it would be a good option other than MSfor launch control i can custom make you an ECU (V6 only) that should be able to do it no worries. i just move the rev limiter to your "launch RPM" then once the clutch pedal is up it will set your upper limit to whatever you want (7000rpm or whatever). i was going to mess with this on my car but the cars getting painted right now.
as for the above diagram i doubt it would work because the current available to go through the coil (lots) wouldnt be able to be shunted with a small transistor (and the resistor only makes it harder, but in theory its correct to use the shift lights power to turn off power to the coil (or before the coil). personally i would use a 2N3055 or similar (MJE3055) to turn off the input to the HEI (where less current is used). this also saves you modding the input to the coil where back EMF will cause high voltage spikes.
^^^^ nice, just like MSnS.
BTW I got my msd 2step set up few days ago, launching never been easier. All you have to do is just wait for sum1 to sell their stuff. I waited about a month till I got my msd 6al + 2step deal for $150 shipped from member on PT.
:lol: i thought mods are ment to delete off topic postsNot to go off topic but holy hell Port Orchard! Born and Raised home town. Welcome!
