Hello, I looked at the title of my car and realized on 5/11/2023 I will have had my MX-6 for 20 years. Allow me a short story time and then ill explain my build plan.
I had 4 RX-7's and 3 MX-6's at the time that this one went down. I had it pretty extensively modified. running an MSD with the internal coil (which worked great) but the MSD after a while had a broken diode which I didn't know. I didn't have time to fuss with it and my friend tried to be nice and took it to a shop. I asked them to not hook up any diag equipment due to the custom harness but they did and fried most of the electrical. couldn't get the thing running after all that to save my life. my other MX-6 got the engine and trans and I kept the shell. Years passed and it sat with no engine or trans but I always wanted to do my "crazy build" I just got my stepson rolling in a 95 LS I picked up in a divorce and it reminded me how much I adored my MX. So to the point.. here's what I have now.
Block, head, and internals for a 2004 protege 5
millina S supercharger
megasquirt 3
no trans currently
new clutch and flywheel.
the plan is I have a buddy that does metal fab, he owes me a manifold and I was intending to fab a manifold to direct bolt the supercharger to the intake of the head. long enough pipes to add injection. run standalone coils (protige5 head means no mechanical distributor). this also means I get to keep my AC because I live and drive in central WA in the summer. The protege 5 engine had an issue with the cyl walls being out of spec so they'll probably need to be bored and honed. I'm looking for advice from all you people like me who love these cars.
Bottom end:
What should I look for that is a good product for the purpose? not intending to get more than maybe 250hp out of it as I want to drive it around on the street.
thanks all for the advice and I hope this post is aligned with all the rules. if not I did read stuff but I have a properly garbage memory.
megasquirt 3
no trans currently
Bottom end:
- Piston/connecting rod suggestions
- Do I need a new crank? or would the crank from the protige5 work
- New valves or keep the original
- new cams or same, keep the original
- debated doing better than stock valve springs but I am open to suggestions.
