1 - 1 of 1 Posts
Hi Folks
I've got this stupid problem with my 2nd Gen that only happens in wet weather...
When I signal right, my rear fog light indicator flashes on the dash and fails to operate the rear indicator. The rear fog light flashes real fast but if you rip the rear light cluster off and have a look at the indicator bulb closely, it does flash really really dim. I know this is an earth fault somewhere but where ? I've had both light clusters apart and sprayed with WD-40 but no joy. I've even removed ALL the bulbs apart from the right indicator and it still wont flash. I have replaced all the bulbs but no joy. Oh, and better still, when it is raining really hard, the hazard lights flash on the dash when I indicate right !
Any of you guys had a problem like this that you managed to sort out ?
Cheers
Paul D
1 - 1 of 1 Posts
