http://cgi.ebay.com/ebaymotors/NEW-93-95-Mazda-MX6-V6-Turbo-Manifold-Downpipe_W0QQcmdZViewItemQQcategoryZ33632QQitemZ8021255002QQrdZ1
USA ebay... dump pipe and manifold for $500... (prolly landed in aus for 800)
Anyone else really wants a turbo 2.5l v6?
What would need to be done? if just say we only wanted to run <5 psi...
Buy a turbo, wastegate, manifold and dump pipes, boost controller...
Will that be enough to get it kickin?? ATM she would run a high 14 low 15 so imagine with a nice turbo kit tweaked and tuned... high 12's low 13's? Monaro Killer...
But to run say 15psi = new fuel managment, ecu, brakes, strenghtened internals etc...
Am i briefly on the right path???
Pretty much on the right path. This has been done heaps (well, 3 or 4 times) on the US forums, so check out the 2G section for full build-ups with pics.
You are going to need engine management even for a low psi un-intercooled setup, however. I can't really see any way around it, unless you run some kind of externally actuated 5th (sorry, 7th :)) injector setup to prevent lean-out.
should........
KLZE headers will fit an KL03
so i dont see why it wouldnt fit
Thats some nice pipework on those headers! The install would be tricky, but all that work saves a fair bit of effort for you!
