1 - 12 of 12 Posts
Hello
First off i'm Jordy from the Netherlands and i want some information about an other ecu for ik my 323f 97' KLZE
The car runs on stock ignition, ecu, maf but feels a bit slow..
for example, last week a Audi 80 2.8 175 hp was chasing me down the highway... taht beast weighs 1450 kg but i had to floor it or i would take a look at his tail lights...
I really can't accept the fact that a 1450 kg, 175 hp car is as fast as a 1150 kg car that should have 200 hp..
Can some one tell me what ecu etc i need? please in simpel language...
When i have some time i want to put it to the dyno and see what it does..
Kind regards
You'd need the ECU and VAF from the engine that's currently in the car.
KL36 and JE50 VAF would probably work best.
Discussion Starter #3
Hello
First off, Thanx!
Do i need something more other than a KL36 ecu and JE50vaf?
Do i need an other engine harnes?
Please exact information..
Kind regards
Don't think you'd need a different harness, over here in the states, we don't mess around with it. :)
Discussion Starter #5
Hello
So, i buy an kl36 ecu with the following numbers: Kl31 18 881B
a JE50 VAF, plug it in and it should work on a 2.0 v6 323f engine hanrness?
Don't see why not. You may already have the JE50 VAF, so check before you buy.
Oh, and the ECU is either KL31 or Kl36. One of them is for an automatic. Don't think it matters.
it seems he had a kfze not klze, he said 2.0 v6, those are kfze and only comes with 170-180hp. required different ecu.
Hello
Kind regards
Is your ZE a 2.0 or 2.5?
Right, which is why i said he needed a KLZE ecu. It says in the first post that it has a KLZE now, which only comes in 2.5 flavor. So he needs that ECU.
1 - 12 of 12 Posts
