1 - 18 of 18 Posts
Okay so as of late there is SOOOO much misinformation going around here about turbo'ing a 4cly it's crazy to me......
So lets set this straight kiddos!!! READY?
First off this question is asked WAAAAY to much
"can I turbo my 4 cyl man?"
YES and it is in my opinion SO much easier than a v6 its ridiculous. We have the fs motor which imho has a much better aftermarket support than the k series motor do.
A lil f series background............
The 2.0 L (1991 cm3) FS was one of the last F-family engines. With an 83 mm bore and 92 mm stroke, it produced up to 130 hp (97 kW) and 135 ft·lbf (183 N·m). In 1998 the engine evolved into the FS-DE by undergoing several changes, most notably a distributorless ignition as well as the move from hydraulic lifters to solid shim-on-bucket lifters. Japan also received a higher-performance version, known as the FS-ZE. A special version of the FS was produced in 2003 for the Mazdaspeed Protegé which was turbocharged, and generated 170 hp (127 kW) and 160 ft·lbf (217 N·m). This was known as the FS-DE-T. It's worth noting that the internals of the FS-DE-T were identical to those found in the standard FS-DE, which were not known for their strength.
The FS-DE engine did enjoy a few minor technical features, such as:
-Oil Squirters
-VICS (Variable Initial Charge System) - A system that can vary the volume of the intake manifold resulting in a broader power band. There were known issues with this system, the most noteworthy was that the small screws would come loose from the butterfly system that drove this and end up running through the motor.
-VTCS (Variable Tumble Control System) - A set of butterflies in the intake manifold that would close to promote low emissions combustion under cold start at low engine speeds. These had a reputation of being noisy at times.
Now you know the history and specs lets get to it.
Lets start with some basics......
The manifold.....
Okay contrary to popular belief the mazdaspeed mani will fit! BUT you will need to grind some off the side by the disti.
No worries though when you have these to choose from....
obx manifold
hiboost
Godspeed
protophile
RPM motorsports<~~~~~ these guys are cool they can custom make them in different configs.
Now you can also use your stock mani as well, that is what I did. i just got an exhaust shop to weld on an adapter plate for 30 bucks and boom insta turbo mani. Now it did help my dad is a machinist so the mani was also ported.
But with that option you NEVER have an issues with fitment. Like our member here Larry did......Props to him!!!
Or go custom... Like so....It is VERY cheap and pretty easy as well.....
JGS Tools
It's a full diy manifold kit for 179.99. Or buy the prewelded one for 322.99
D.I.Y kit
Premade kit.
JGS Tools
Engine..... Start with these first two I consider them a must for a decent turbo set up.then later if you want a rebuild then you can move on to pistons and rods.
GET ARP'S!!!!!! They make them for the mp3's and the msp's as well.
StreetUnit.com - Premier MAZDA/MAZDASPEED SPECIALISTS
Headgasket
cometic
Pistons
Weisco
cp
Rods
Pauter rods
I wasn't going to touch on fuel at first and tunning at first but here is a "crash" course.
Injectors
J-yard!!!!That is where you can all kinds of goodies!
Turbo probe/mx6 injectors
I really recommend dsm turbo injectors 450cc
EARLY mustang 5.0 the injector will have 400 on it the injectors 440cc
OR if you are a big baller get injectors from a natural gas crown victoria 1600cc!!!!!
Fuel pump....
Walbro 255lph HP<------Be sure to get the hp(high pressure)
Automotive & Diesel Tuning, Diagnostics & Performance.
And tuning.......well go megasquirt or go home!
I will update this as I find more information.
hey w
hi i am new on here i am puting on a turbo on my 2 gen mx6 where can i find the oil lines to tap off so i can run them to the turbo
thank you
How much power can I expect from a properly turbo'd fs? It's a vague question on purpose. I was planning on building up the engine with the kit from import performance, and sticking a t3/t04e on there. Is it reasonable to expect 250whp at a manageable (not blowing the engine) amount of boost?
Discussion Starter #5
Well your first issue is that saying a t3/t4 isn't saying much. You need to know your cfm's your chosen snail is pushing.
250 on a completely stock block.....No fuel mods or tuning? Umm that's prolly a no go. Your would most likely run lean and get detonation, if not that then you could easily blow the head gasket. If you plan on this check your compression first make sure that your rings are good then get arp's, a cometic, afpr, a waly 255, larger injectors and for god sakes SOMETHING to tune with. now 180-215~ whp that's prolly a bit easier and achievable while still offering some sort of reliability.
hey guys, i was thinking to turbocharge my 2,0, but leaving stock ecu? any idea how pressure could it manage? Lets say it would be an economic project ;)
i've talked to some local mx6 owners, and they've told me, that if my stock ECU or airflow meter sences boost, then it would cut fuel, or in the best scenario it would run lean and couse damage to the engine. I'm talking about low boost like 6PSI or so, and i'm trying to avoid megaquirt :(
What do you think?
it wont cut the fuel at all. but the FS ecu doesnt do well handling boost really. you can do it. but dont be expecting to make any real decent horsepower #'s. but if your just tossing together a low budget basic kit just to have a turbo. it will be enough as long as you address the fuel system.
6cyl power troubles
Ok so i know this prolly isnt the right place to post but i have serious troubles navigating websites. im trying to figure out the best way to get good power out of my 6cyl mx6. I want the mr speed kit but being out of business i cant find one. im not against turbos but am trying to create more of a display car and dont care for the rusted exhaust pipes. im open to advice and redirection. any help would be greatly appreciated
haha...all the threads in this forum and you pick the 1 for the 4 cyl...;)
the forums this thread is in, just read around it to get started, though...
Just have one question-where Mar suppose to be?on pressure side or Turbo air feed side?
I know it's been a while since anyone has been on this thread but I have a quick question....I'm turbo'n my lil 4 banger and I just want to know if anyone has a line on some high performance cams For the fs motor
Super Moderator
@treslerbt
Edited your post. Only need to post a url to the img not the photo bucket link. Try right clicking and opening image in new window, and them posing that url instead.-Don
Looking good though. Which manifold is that? Looks like a stock manifold with flange welded on.
I tried with just a flange on the stock mani but it was to low and close to the block so I had to cut it into many pieces lol, this was the end result.
1 - 18 of 18 Posts
