1 - 20 of 35 Posts
I bought my car knowing that it had 4WS, but it never worked. I was wondering if anyone knew why. My rear strut mounts are broken I'm not sure if that's the problem.
Oops sorry! I'm driving a 93 MX6 LS V6 (second gen I love my baby) and no the light isn't on. Thanks for the fast response.
no 4ws light will 3 things ... the bulb has blown, check it, the 4ws ecu is not plugged in or has power, check that, its in the boot, black box. and finally the problem is not electronic, possibly meaning the broken top mounts are affecting it, you should get these fixed anyway if they are severly broken, as when you jack the rear of the car up, the wheels will stay in the floor, strut and all ...
I unplugged the one at the left side of the boot to see if a light would flash or whatever, but not light or anything now my car won't start. :l
have you plugged the box back in ? and when you say not start, you mean turn over ? not fire, spinning over ok ?
Yeah I plugged it back in, it turns over fine keeps turning at a normal rate the fuel pump buzzes but the car refuses to start. (thanks for the fast reply)
Check fuses in the engine bay. If you have not done anything else apart from find this box and disconnect it, then its possible you have blown a fuse.
Haha anyways I don't think I found the 4WS module. I'm going to check the fuses in the morning and come back with my reply, thanks a lot Oddball.
Discussion Starter · #12 · (Edited)
I checked the engine fuse in my car and it's fine. It's still turning but refuses to start... Wow, I don't know what to do.
ok .. well you need to check you have spark, pull a plug out, connect it to its lead, rest it on the engine and have someone crank the car or watch the plug and see if it sparks. If its sparking, you then need to check fuel.
And you deffinately did nothing other than unplug a black box in the boot ?
The fuse to check is the pink ENG/INJ in the box in the engine bay.
Discussion Starter · #14 ·
I just had my mechanic take a look at it, it's the distributor one of the wires cracked due to the cold. Kinda pricey to buy but either way I'm glad he figured out what was wrong. Thanks a lot though.
No probs ..
Ok, i thkn i know which black box you found, and was it just below or next to the trunk catch ? if so thats the rear light cluster check control box. The 4WS control box lives in the left hand well behind the wheel arch or on that side inner wing. Thats where you need to check, and also check for any voltages on the pins of the wiring loom.
Discussion Starter · #16 ·
Alrighty this is actually what I found..
Directly under the radio near tand under the shift boot
Oh so THAT'S what's in the trunk! I saw that when I was hooking up a ground wire to my car thanks I'll check that out when my car is up and running again.
nope .. thats the engine control unit (ECU) .. the 4ws control unit is in the trunk/boot .. the rear light cluster check control unit is like a large realy.
Discussion Starter · #18 ·
Yeah I know I found it when I was grounding my amp a while back but never knew what it was, but that unit in the picture is the thing that I unplugged. I hope that I didn't mess that up somehow and my mechanic is wrong about it being the distributor that is causing no spark.
Ok well, as long as you have plugged that back up correctly, is shoud be okay, try reseating the plugs to it, as everything was fine before you removed it. Does the Check Engine light go out when yo are trying to start it ? it should come on at ignition to on and the dash shows all the check bulbs and then they go out apart from oil and battery, does the check engine light go out ?
Discussion Starter · #20 ·
Nope I put my car on and when I try to start it it stays on, so it's weird. I kept reseating the plugs but still no luck. So I hope it is the distributor I hope my mechanic doesn't fix it and then it still won't start. That'd seriously suck. If there was a problem with the ECU the check engine light wouldn't go on while trying to turn am I correct?
1 - 20 of 35 Posts
