thanx, i will get some practice, i have only raced my 6 a few times, won a couple lost a couple, but never could really get a good launch, thanx for the reply!!!
best things for launch is tuna on wheat toast or hot roast beef on a roll with mayo lettuce and pepper :p
only kiddin :D
best things to improve off the line launches would be:
Clutch
Lightened flywheel
underdrive pulley
Limited slip differential
smaller, lighter wheels
better gripping tires
suspension work
motor mounts help a little
and of course, PRACTICE
none of those things actually gain horsepower, but they will all improve 0-60 times, 60ft times and 1/4 mi times. of course giving your engine more hp will entail better launches, but first, i'd utilize the power you have better. all the above mods put existing power to the ground more efficiently.
hope this helps
L8R
Nick
BLUMX6
and actually, i found that riding the clutch SLIGHTLY helps reduce wheel hop and wheel spin, hence a better launch. just dumping the clutch results in bogging unless you have clutch and flywheel mods.
