not really, I just thought you were dumb because you have a LX and I thought that you were thinking about installing a 5th injector on a N/A lx. because you never stated that it was custom turboed. Oh and FYI, I highly doubt you could beat me. First of all the most boost you can run is like 9psi's because of your high compression, and even then you will probly need really high octane gas to prevent knock and more fuel otherwise your limited to 7psi's.
I see no mods in your sig so im guessing your basicly stock except for the stock GT turbo and intercooler, boost solnoid, pipping ect. and your probley running stock (7psi's boost), because the LX injectors will max out at anything higher, and GT injectors will make the car run rich when off boost. Unless you took care of all the fuel problems, which I don't think you have judging by the tittle of this thread.
now I have a Adam's chip to get rid of boost cut so I can run 15psi's, I have a hollow cat with a 2.5" CAT back side exit exaust, I have a cold intake with a K&N drop-in filter, I have a Ball & spring MBC so no turbo lag. I also have acell 8.8mm performance plug wires and a 0.040 cylinder overboare.
I don't have a tonn of mods (I still have a way's to go) but IM willing to bet that I have more mods than you..and even if I don't I can run 8psi's more boost than you can. so all-in-all...no IM not jelous. also my car is built for boost and performance your's isn't, IE: stronger axles, stronger trans, AAS, upper and lower rear sway bars. ECT.
methman
