Only 2 things can cause the engine to overheat, the thermostat or the head gasket .
If the tstat doesn't open the temp will just keep climbing above operating temp into the red at idle or when driving under any load within 10 minutes. head gaskets usually fails under heavy engine load. Your description of the N/A engine failing sounds like the head gasket was the cause of the overheating. Coolant has a pressure of 15psi and runs 110degrees, cylinder pressure is in the hundreds of psi and combustion temps get up to 18000 degrees, when the head gasket can no longer seal/separate the two cylinder pressure and heat are pushed into the coolant chambers and the engine overheats.
No I would not assume it's 1 in 1000 and I have seen it happen several times with cheap head gaskets. I have installed hundreds of felpro head gaskets on F2 motors over the years, they don't melt. If you pull a head that has a felpro head gasket, the gasket looks new, like it's good enough to reuse but why risk an engine for a 30$ gasket.
The block in my 626gt came from a friend who bought it for the transmission, he had an FE3 to bolt it to and drop in a Protege but his cancer came back and he sold everything.
When I started tearing down the block I noticed it was fleshly rebuilt, all the seals where new and all the parts where clean, the head gasket was melted to shit, from the look of the seals that where on it I think they used a Mahle gasket kit. Head gasket melted after the rebuild, they scrapped the car and my buddy bought the engine.
My shop partner got us some discount head gaskets from BBW autoparts they also melted.
Why do you say gaskets will cost as much as the car?
My whole point is to save you money, you bought the F2T, you need to buy a clutch and you've already got the car. If the 30 year old head gasket goes than it's all wasted money and time. If you decide to repair it after the fact than it cost a lot more than changing the head gasket at that point.
