Sorry for not posting for a while, things are happening but only very slowly.
Managed to get the sump off the old broken engine, got a piston out and got a ring off it to replace the broken one on the new engine.
So all pistons are back in the block now.
Also cleaned out all the loose matter from the coolant passages etc.
Main hurdle at the moment is trying to find a part number for the splash plate gasket (or what the Mazda workshop manual calls the "stiffener") - i.e. between it and the block.
The Felpro kit I ordered only contained the gasket for between that and the sump (oil pan) itself and after lots of searching I can't find anything online.
Should I just use sealant without a gasket? Seems to be what the workshop manual suggests
Also - @Mazda Carnage regarding your tip about torqueing the oil pickup in advance to "pre crush" the gasket etc - I went to do this but it's just a paper gasket, so I can't see the point? It only makes sense to me if it was a rubber gasket.
One other question - this may have been my fault from removing the sump, but there is a gouge in the material of the block near where the oil pickup bolts on. I got rid of any small loose pieces of metal, but is this likely to be an issue?
And just thought I'd drop a pic of where it's currently at:
As an aside - I have now ended up with another 626 parts car which could be handy - my mechanic had a customer who wanted to get rid of it and knowing I had this project, he put me onto him and I bought it very cheaply. I gave it to a family member who was in need of a car and it did a solid 5000km or so of driving before overheating.
Thinking it may be the head gasket I did a compression test and all cylinders were around 120psi, except #1 which was a few psi less. However, while I was testing # 2/3/4, a bit of coolant spat out the #1 spark plug hole - is there any way this is anything but the head gasket?
If it is the head gasket, I'll just turn it into a parts car.
