Will 626 headlights and tail lights sit and MX6 I found a 626 being parted out just curious what all will swap over as far as body parts exterior interior. Yes I searched the search function and I could t find much info
The headlights will bolt up but have different brackets for the chrome trim and marker lights.
The dash, carpet and roof liner are the same. The sunroof and assembly is the same, the widow motors are the same but not the track.
The hood and everything under it is the same.
You can use these to cross reference 626 and MX6 parts:
http://manuals.wibla.net/mazda/mx6_8892_cg.pdf
http://manuals.wibla.net/mazda/626_8892_cg.pdf
Thank you for this info. I appreciate the help.
I tried using carpet from a 91 626 in my 91 MX6 and found that the front part was almost the same, but the back part seemed to stick up at the end of the "transmission" tunnel, just as it transitions upwards towards the rear seats. I tried more than once to get it to work and finally said fuck it. I also found that some of factory holes (for the seatbelts and other covers) didn't necessarily match between the different models. My guess is that others have had better luck than I did though, but it can also be said that the two carpets are not the same.
Oops, there are also two long flaps at the very rear of the 626 carpet that will need to be cut off that are not on the MX6, plus the 626 has those weird square cuts for the air vents to the rear passenger area.
