Leaking injector
Air Leak ie cracked throttle body boot.
Faulty AFM
Faulty Fuel Pressure Regulator
Just to name a few. need more details to give a accurate over hte net diagnosis.
does the car have an irratic idle... like it will normally idle around 750 (where its supposed to) then jump between 1500 or so and lower???
if so.. then you have a bad fan control sensor
either...
#1 replace said sensor
or
#2 unplug the sensor and ground out the lead. this creates a closed loop circuit and your cooling fan for the radiator will stay on all the time
how do you know it's flooding? if you're smelling gas you could have a bad injector or injectors, and you have fuel leaking somewhere.
