1 - 1 of 1 Posts
Trying to troubleshoot this problem, start won't even crank. I am looking at the 89 Factory Wiring and it looks like the Clutch Depress Interlocking Switch is in series with a Starting Cut Relay, but where is the Starting Cut Relay located? It's labled D-02. Is this under the dash somewhere or under the hood?
EDIT: I may not even have one of these. I see a dotted line on the schematic in the factory manual that says Without Theft-Deterrent Control System, which I don't have. That could explain why I can't locate the dang thing. What else should I be looking for, car won't even turn over. I have the Clutch Depress switch jumped out.
1 - 1 of 1 Posts
