1 - 10 of 10 Posts
That i know of theres no spring the connect to the DP to CAT. :confused:
I'll try to get a picture of it, But I already found it. Thanks!
Edit
if anyone wants to know what it is its a M10x1.25. The same thread as the tops of the 4 posts for the Suspension struts/springs.
Are you talking about the 2 18mm head bolts and tapered-like springs that bolt the two together?:shrug:
I have ghetto springs too. The spring does taper. Someone threw a bolt through and welded the darn nut to the bolt... The springs are about 1.5" long.
What if you go to your local hardware store. Use you imagination!
I was looking around at my local auto parts store and found the "spring and bolt" combo! They were $3 for the 1 spring and 1 bolt! There is your answer
1 - 10 of 10 Posts
