hello there ,
just have a simple question as to what engines come standard from the older 929 turbos. i beleive they are 2L turbos, are the engines on these cars called the FE3-turbo, or are they called something else.
I personally thought that FE3's didn't come in turbo - factory...
any feed-back would be good, i have a friend selling her 929 turbo, call is full of rust but engine meant to be pretty good. if it is the Fe-3 mite be worth while getting. and if so will these fit into a 1st gen MX6 - with similar engine mounts?
It's not the FE3
I'm unsure of the engine code...but it's a 2L SOHC engine.
You'd be going backwards from what you've got now....
Pete
FE turbo Same as AS TX5 Turbo or 85-87 626 turbo i think,
BF should know this one
