Hi all,
I got a 93 MX6-LS 5sp. I got the following problems with the car lately:
-- Airbag senser is now flashing
-- Driver Power seat stop working
Is there anything that I can do to fix it beside taking to the dealer ?
Thanks very much in advance and please direct me to the right forum if I am at the wrong one.
dtammx6
Discussion Starter · #2 ·
I'm a 1st gen guy, so I can only give you general information. The best place to ask for specific information is "2nd Gen Maintenance".
Anyways, your airbag light is probably flashing an error code, A quick look in the FAQ's in the 2nd gen section might help there.
The driver side seat? I'd first check to see if theres a loose connection or a blown fuse, after that, I'd remove the switch unit and spray some Electronic clean and lube into it, and work the switch a few times.
If that doesn't help, you could try running 12 volts to the seat motor directly to see if it is at fault.
thats what i'd do :tup:
