Hi all,
Long story short I recently bought a new project car, a 94 MX-6 2.5L, that had been sitting in someone's yard for quite a number of years. A few issues, the main one being, the car cranks but does not start. I have tried installing a brand new distributor (not OEM) that I got off ebay. And still there is no spark going to the spark plugs. And when I turn the key to the ON position, one click before START, I can hear one of the relays in the engine bay clicking 3 times. Another side issue that had got me thinking about possible reasons this was happening is, the window switches and sunroof switches are intermittent. For example, I can put the passenger window down on the drivers side, but not up, it has to be put up again by pressing the button on the passenger side. And the Sunroof opens but does not close. I had to pull the headliner down and close it manually by hand with a Torx screwdriver. And when I press on the drivers side windows to go up the A/C fans blow at MAX speed, and only while the button is pressed. This got me thinking that because the car had been sitting for so long then perhaps the grounding strap could possibly be corroded or damaged. Causing weird electrical problems.
Any knowledge or help on this situation would be greatly appreciated, as I am not a mechanic and I am trying my best to learn! Thanks in advance
192.168.8.1
jiofi.local.html
Router Net - Default Router Settings Details
192.168.8.1
jiofi.local.html
