When I run my A/C in my car it is leaking all over the passenger floor. So much so that the was carpet is completely soaked this mornign after a 1/2 hr drive.
I believe there is a drain for the A/C that I am going to check. Has anyone else seen this if so what was the fix?
Your duct work under the glove box has come undone. Look under the glove box for the heating and air duct I think its like three places that it could have come undone from. I had this problem a few years ago, and that is how i stopped it.
Hey I fixed i. The drain hose was full of crap and wouldn't drain. I shopped vac'd out a crap load of water from the floor. All is good now
Hey..where is that drain hose??
I've been looking for it for a while and can't find it. It's hot as hell here and I'm tired of wet carpet!
Thanks
Pull off the plastic cover under your glove box and between all of the duct work and the firewall is a rubber hose. I just pulled it right back into the car and then disconnected it. YOu should be able to see it from inside you engine bay also. It only come out about 1 in.
