I found this piece of piping from a 91 Saab 9000 Turbo. I don't quite know what I'll do with it? It's aluminum (+) and has in inlet that can be used to adapt to the bypass (stock bypass but could also be used with the 1G somehow via rubber hose)
I don't know which way I'll use it or if I even will?
I was thinking that I could use if from the turbo to intercooler, but at closer inspection, it could probably be used from the intercooler on up to the throttle body. In which case I'd use the inlet to connect the bypass en'route to the throttle body.
Check it out:
Notice that the length and angles of bends take it to the throttle body boot (which I would change for a nitrile or similar 90 bend)
Obviously you'd have to move some stuff around as it isnt an exact fit.
But it also comes very close to reaching the lower intercooler outlet:
And it also has an allready ready allready opening which could be used to route the pressure from the bypass:
Again, not an exact fit, but quite similar:
It doesnt reach fully to the intercooler, so some sort of rubber transition hose would need to be used for a couple inches:
And of course the piping itself is 2" instead of 1 7/8":
Check it out:
