posted this somewhere else, thought others might think it useful...
Door panels. I got same problem with my drivers side, here's how I fixed it.
The problem is the panel is broken inside the handle under the lil cloth pad. There is one screw that goes straight down through the panel and into the door. The panel breaks with wear and the screw slips out of the panel and voila, it's off.
To fix, I just cut a piece of metal the same size as the bottom of the handle hole. punched a hole with a very small nail where the screw fits, then put the screw back in through the metal piece, through what was left of the panel, and into the door. Then got some epoxy glue, or something that would stick to metal like double sided adhesive, and reinserted the small cloth piece. My panel hasn't come off since.
Things I'd do differently? I would have glued the metal piece to the bottom of the panel. The ends bend up when you put the screw in. Also, coins slip under the metal for same reason. I'll redo it someday.
Hope this helps some more folks.
HR
When I first got my car, I replaced the factory speakers. Not knowing how to remove the panel I wriped it off so hard that I cracked/stripped a lot of the plastic fasterens that go on the inside of the door panel. For a couple of months it would go it and always pop off. Then I went to a Mazda dealer, got like 10 new fasteners, installed them and not the panel doesn;t even budge. I don't even have to have any screw screwed in, the panel still doesnt come off unless U really tug on it.
Just my $.02
