mx6invader said:
you have to shift faster, because its kinda like a safety feature where as if you are going to fast for that gear it will not let you enter. Thats why if some reason you are going from 5th to 3rd and accidentlilly go to first it wont let you. Ive noticed that too, and i just started to shift faster out of first ... Dave
Umm, no
You can make a 5 to 1 shift in an mx6. The reason it "wont let you" at speed is because the synchro is begging you not to. If you push hard enough, it will/will break. Some trannies do have lock-out solenoids, the T56 comes to mind. G25M-R does not to the best of my knowledge.
Shifting FASTER from 1 to 2 will only aggravate the problem? Where on earth did you get that idea?
Replace the tranny lube with Redline MT-90, which is known good and safe. Clutch in, pull out of first, wait for rpms to fall sufficiently, only then apply pressure to second gear. It should slide in easy. If it slides in easy enough, but makes noise, you have a shifter or synchro problem. Good luck.
The tranny fluid is prolly long overdue for a change anyhow. I get Redline MT-90 locally for ~12 bucks a quart. You need 3.
-Garrett
