Hi guys,
Ive done the search etc, but found nothing in relation to my problem... SO here goes.
ABS light was on, the joker who had it before bypassed the the brake lines to make it non-ABS because of an ABS malfunction, I go an buy another ABS unit,
install it and top up all the fluids.... ABS light is now off... BUT only after flashing 4 or 5 times on start up. Brakes are spongy so i bleed them and after doing so are feeling much better but are not perfect(not enough to get over the pits) THE MAIN PROBLEM I HAVE is that the dash lights flicker on an off when you plant the brake pedal..WTF is that? brake guy reakons my ABS is faulty or there is an elec. prob. cos it wont bleed properly either, thus the slight spongyness from the pedal.. anyone had this problem or a solution to it?????
Thanks guys
Thanks guys
