1 - 1 of 1 Posts
Hey guys, done a search and haven't found a definate "how to" on this subject.
The symptoms
My abs light was flashing 4 times after starting the car, and staying off. Now, ive topped up the brake master, and also the abs unit. Now im getting one flash, and then after reaching 15klms the light comes on and stays on and the abs isnt working.
How do you pull the ecu codes on a 1g mx6? What are the plugs/pins i need to ground to pull the codes?
Also why would my abs light change flash codes?
Thanks for the help.
1 - 1 of 1 Posts
