Does the ECU record faults from the ABS system..?
If so how do I recover them?..
My ABS light comes on on the dash some times and I know my breaks are not right ..
cheers..
When you turn the ignition on, the ABS light will usually flash out a code (at least mine does).
The best process for this is listed in the shop manual. A search here or on probetalk will list out the steps that I have put down way too many times. If not maybe someone will post the page for you.
Well I wouldn’t want to put you to any trouble thanks for your effort..
Before this post a search under ‘ABS codes’ would have come up completely blank…
I guess Ill just go to probe talk.. what ever I find out ill put on mx6.com so some one elce may get the benefit from it..
its a simliar procedure to the ecu (engine ) code.
i did have the workshop PDF somewhere on my hard drive, detailing the procedure.
Another thing from Woo.
I will try to find it and link it somewhere.
Do you have anywhere i can upload it too ????
where can i upload a 8.3 mb pdf file too?
Anyone offering?
I only get 9838 Kbytes :(
