Everything was good, until I put in a new radiator. Now the ac compressor will not turn on, and the ac cooling fan will not turn on. I suppose I dislodged a wire or 2. The ac has no leaks. When I push in the ac button, the engine increases revs, so that is working.
Question: where best to look for the wire problem ? I don't even think it is down by the compressor, because the cooling fan also does not come on. There is a big batch of wires between the radiator and frame........do I have to somehow get that freed up, and look there ?
Discussion Starter · #2 ·
Found a wire that had a bare spot and touching metal. Fixed that and ac is back again for the summer. I was testing the relay box in the main fuse box. One connection there all you do is put ground to it, and the condensor fan will start up. I guess it gets a ground connection when the ac button is pushed in.
