I HIGHLY RECOMMEND THE ACT II
When I first had it installed, I would ALWAYS have a problem shifting into second gear. I would always get a "GRIND" at high RPMs. But then I switched my tranny fluid to REDLINE, and the grinding went away. Now I'm stuck with the extra effort that I have to put in to get it into second. If I would've put that REDLINE in when I got my ACT installed, I don't think that I would have a problem shifting into second at all.
I ALSO HIGHLY RECOMMEND THAT YOU USE REDLINE SYNTHETIC TRANNY FLUID, WHETHER YOU HAVE A STOCK CLUTCH, OR AFTERMARKET.
THE BOTTOM LINE: Put redline fully synthetic fluid in your car ASAP, and get an ACT over all the other aftermarket clutches available... Even stock...
HTH
