ok. so i have a ze, and it has a ect sensor on the im. i have a 94, and the 94's don't have that sensor. i also had picked up a free ecu that was programmed with ze specs. the ecu is a 93 though, and is looking for the ect sensor. having it not be there is defaulting the fans on at all times. i am trying to figure out if i would be able to add a wire to the wiring harness by running a wire from the sensor to the plugs that plug into the ecu. this way the ecu would get the signal it expects, and the fans would be working properly, instead of on all the time.
is this possible?
if you have the 2 CTS' with two wires each over on the passenger side of the engine, you can probably use one of them to provide a signal.
