I learned this technique years ago, but I thought I might post it here just in case some people haven't tried it out. What I do is first adjust the rear view mirror inside to frame the back window. Then I adjust the side mirrors so that the inner edge of the mirrors can just see what is visible on the outer edge of the inside mirror.
That way, as a car is passing you, you will first see it in the inside mirror, and as it leaves the mirror's field of view, it can be seen entering the side mirror's field of view. You basically get a continuous view of cars going by. It's like having one big mirror, but it's in 3 sections with a continuous view.
Here's another way to explain it in these articles:
http://www.securitydriver.com/aic/stories/article-101.html
http://www.racingschools.com/tips/mirror.shtml
This is the technique that race car drivers use on the track. They don't shoulder check if their mirrors are adjusted properly. I actually learned this method at a BMW test driving course. Before, I used to set the side mirrors to see the side of the car which you really don't need to see and creates redundant areas in the mirrors.
I still shoulder check when I'm driving in a 3 lane or wider road. There is still somewhat of a blindspot when both drivers are in the far opposite lanes I find. When you are both changing into the centre lane, you really have to be careful still.
With the 2nd gen side mirrors, I find there's a much larger field of view as compared to a 2000 626's smaller side mirrors. Even with adjusting the side mirrors as mentioned, I find the field of view quite a bit limited as compared to my old MX-6.
Try this technique out if you haven't already, and see what you think of it. Just be careful getting used to it at first since it's weird not being able to see the side of the car!
