1 - 1 of 1 Posts
I would like to know about your temp settings.
Are you using your ECU to control water temp and if so, what are your settings for On and Off set to ?
On the highway, what temp do you find your car gets down too?
And what is an ideal temp range to be aiming for ?
I am still using the factory temp sendor for the speedo cluster temp guage.
The EMS i have, has its temp probe in the thermo cover where the fan switch use to be. I am using an output of the EMS to control the cooling fans.
I am trying to fine tune the temp settings and i may even end up retro fitting the factory fan switch and fitting the EMS temp sensor eleswhere.
1 - 1 of 1 Posts
