I was wondering if any one here is running the EMS 8860 ECU on a non-turbo fe dohc? Just wondering because i know you can save the ECU settings to your PC and well share the welth with the rest of us that are looking to go with an aftermarket ecu.
Cam22 is running the dualsport. I believe the software they use is the same, so you should be able to import his fuel and timing maps.
However, he is just running on a leaned out F2t map at the moment (Or at least, last I heard).
thats about the jist of it.
But the only prob is, Different EMS models cannot share there maps.
Stinger can share to stinger
8860 can share to 8860
Dual sport can share to Dual sport.
etc.
I am toying with the idea of wiring the new loom i have found (FEFE 2pin factory ecu) into my car. to see how many pony's this new engine will push in NA form
etc.
Yeah that is what i figured would happen.
How much did your set up cost you?
Drive away price, including boost controller and hand controller.
All installed and tuned.
About $2600 AUD. approx 4 years ago.
