1 - 8 of 8 Posts
Hey i own a Mx-6 95 auto 4cl L4. I was wondering where i could get a turbo for it. I heard that u can use a rx-7 turbo, does anyone know any of this do u guys have any clue of the cost??
The best bet would be to get a Probe Turbo from an I4. Then you can get a boost controller. If not that then go to probe talk and see what they have as far as step-up turbos. The stock ones are fairly small. Consider a step-up.
Trevis
you probably could use a turbo from an RX-7 as well as any other turbo that fits in the engine bay...
turbos are pretty much universal...
I thought that it wouldnt be good to turbocharge the 4 bangers cuzz i thought they had high compression.
you can add a turbo to anything as long as you wotch your boost levles. a factory turbo off of any old subaru would be better than the RX-7, the turbo off the RX-7 is tiny. You could get a referb one for around 400$. Or if your brave 25-50$ in a junk yard.
lower than the V6... 9.0:1 if i remember correctly...
1 - 8 of 8 Posts
