Guest
·Guest
Its blinking 3 and 4 times at a time....what error code is this? Plz respond
Code 34: Driver's side air-bag / safing sensor: low resistance or shorted.93LoW3RdMX-6LS said:Its blinking 3 and 4 times at a time....what error code is this? Plz respond
If you pull the bulb an annoying beep goes off like 34 times every 25 minutes. So, instead I tried painting the bulb black. This didn't cover the light completely so I experimented with different ways to wrap it with electrical tape. (Cover every place, even those tiny cracks where the bulb contacts are.) I took the dash back out later to see it the tape had melted and it did not. So, I think this is a quick inexpensive fix to a expensive problem since I am afraid of the air bag anyway.JPMX6GT said:I get the same code, but that's because I removed the air bag.
Pulling the bulb....
