1 - 12 of 12 Posts
My aircon stopped working a couple of weeks ago, the day before it stopped working it was fine, was nice and cold then the next day all it did was blow out warm air. When i turn the aircon on now, the thermofan comes on as usual and I can hear a noise, sounds sort of like a rattling or the sound of gas coming out of the front left of the car. I checked the pipe with the red knob and glass window on it, I could see a a liquid flowing through it which im guessing is normal. Does anyone have any idea whats wrong or if its as simple as getting the system regassed? Cheers.
Either you got Low Gas
Or A Leak which would cause low gas
or the clutch in the air con is fubar... see if the air con kicks in or not.
Discussion Starter #3
It kicks in, the revs increase/decrease slightly when I turn it on/off which is normal.
its on the correct setting ?
sounds like LOW gas to me... but im no aircon expert...
pump might be gone.
which would leak the gas eventually
When you look into the inspect window, are you sure you see any fluid?
Could be totally dry! :p
Seriously though, run your air-con for a minute than turn it off and run back to the inspection window and see whether you have;
Bubbles suggest your low on gas.
If it foams than returns to clear, it ok.
Or try touching the inlet and outlet pipes on the compressor to see if there's a temperature difference.
Lastly check your condensor core for a wet patch.
90% of times, gas leaks out from the condensor after a rock/bird/cat strikes a tender reigon.
Discussion Starter #10
Woops I forgot about this thread! Yesterday I unscrewed the red knob on one of the pipes and pressed the valve in, a bit of gas shot out so theres definately gas in the system and it couldnt have been a slow leak (man that stuff stinks), I'll check the pipes and window later on I promise this time :)
Discussion Starter #11 (Edited)
Yep theres fluid in there. I did what you said and ran the aircon for a minute or two and it bubbled a bit then returned to clear. The inlet and outlet pipes on the compressor had a noticeable temperature, the one with the blue know was cold the one with the red knob was slightly warm so I really dont know whats wrong with it :-(
1 - 12 of 12 Posts
