I found this in a google search earlier,
Technical Bulletin
1/06
Use of RTV and Anaerobic Sealer For
Automotive Engines
The AERA Technical Committee offers the following information regarding the use of RTV
and Anaerobic Sealer for automotive-style engines. This information should be considered
before applying sealers during engine assembly.
Three types of sealers are commonly used in engines. These are RTV sealer, anaerobic gasket
eliminator sealer, and pipe joint compound. The correct sealer and amount must be
used in the proper location to prevent oil leaks. DO NOT interchange the three types of
sealers. Use only the specific sealer, or the equivalent, as recommended in the service
procedure.
Pipe Joint Compound
Pipe joint compound is a pliable sealer that does not completely harden. This type of
sealer is used where two non-rigid parts (such as the oil pan and the engine block)
are assembled together.
Do not use pipe joint compound in areas where extreme temperatures are expected.
These areas include: exhaust manifold, head gasket, or other surfaces where gasket
eliminator is specified.
Follow all safety recommendations and directions on the container. To
remove the sealant or the gasket material, refer to replacing engine gaskets in the
appropriate service manual.
Apply the pipe joint compound to a clean surface. Use a bead size, or quantity
specified in the procedure. Run the bead to the inside of any bolt holes. Do not allow
the sealer to enter any blind threaded holes, as it may prevent the bolt from clamping
properly or cause component damage when the bolt is tightened.
Apply a continuous bead of pipe joint compound to one sealing surface. Sealing
surfaces to be resealed must be clean and dry.
Tighten bolts to specifications. Do not over-tighten.
RTV Sealer
Room Temperature Vulcanizing (RTV) sealant hardens when exposed to air. This
type of sealer is used where two non-rigid parts (such as the intake manifold and the
engine block) are assembled together.
Do not use RTV sealant in areas where extreme temperatures are expected. These
areas include: exhaust manifold, head gasket, or other surfaces where a gasket eliminator
is specified.
Information is from best available sources and is accurate at the time of publication. However,
Jasper Engines & Transmissions ASSUMES NO RESPONSIBILITY and cannot be held liable for any
results or consequences regarding the use of this information.
RTV Sealer - continued
Apply RTV to a clean surface. Use a bead size as specified in the procedure. Run the
bead to the inside of any bolt holes. Do not allow the sealer to enter any blind
threaded holes, as it may prevent the bolt from clamping properly or cause damage
Assemble components while RTV is still wet (within 3 minutes). Do not wait for the
RTV to skin over.
Anaerobic Sealer
Anaerobic gasket eliminator hardens in the absence of air. This type of sealer is used
where two rigid parts (such as castings) are assembled together. When two rigid
parts are disassembled, and no sealer or gasket is readily noticeable, the parts were
probably assembled using a gasket eliminator.
Apply a continuous bead of gasket eliminator to one flange. Surfaces to be resealed
Spread the sealer evenly with your finger to get a uniform coating on the sealing
surface.
Do not allow the sealer to enter any blind threaded holes, as it may prevent the bolt
from clamping properly, or cause damage when tightened.
Important: Anaerobic sealed joints that are partially torqued, and allowed to cure more
than five minutes, may result in incorrect shimming and sealing of the joint.
from seating properly, or cause damage when the bolt is tightened.
After properly tightening the fasteners, remove the excess sealer from the outside of
the joint.
Technical Bulletin
1/06
Automotive Engines
procedure.
Pipe Joint Compound
RTV Sealer
is specified.
RTV to skin over.
Anaerobic Sealer
surface.
the joint.
