1 - 16 of 16 Posts
Here we go, this is almost all of the torque specs for a KLDE (I'm assuming they will be the same for a ZE) I will be adding more so keep looking! And as always karma is greatly appreciated ;)
ACCELERATOR PEDAL
AIR BAG SYSTEM
-Drivers side airbag module = 70-104 in. lbs.
-Passengers side airbag module = 13-20 ft. lbs.
-SAS unit = 61-104 in. lbs.
AIR FLOW METER/SENSOR
-Mount Bracket Bolt = 70-95.4 in. lbs.
ANTILOCK BRAKES / TRACTION CONTROL SYSTEM
- 12-17 ft. lbs.
AUTOMATIC TRANSAXLE
-Automatic transaxle mounting bolts = 70-73 ft. lbs.
-Torque converter mounting nuts = 28-45 ft. lbs.
-Shift control rod bolt = 12-16 ft. lbs.
BRAKE CALIPER
-Brake hose to caliper banjo bolt = 16-21 ft. lbs.
-Front caliper mounting bolts = 22-29 ft. lbs.
-Front caliper mounting support bolts = 58-75 ft. lbs.
-Rear caliper mounting bolts = 26-28 ft. lbs.
-Rear caliper mounting support bolts = 34-49 ft. lbs.
CLUTCH SWITCH, ECM
- 11-13 ft. lbs.
DISTRIBUTOR LOCK BOLT
- 14-18 ft. lbs.
FRONT AXLE
-Axle nut =174-235 ft. lbs
REAR AXLE
- 130-174 ft. lbs.
ENGINE
And theres more to come ;)
Discussion Starter #2
COOLANT TEMP SENSOR
12-17 ft. lbs.
FUEL FILTER
Fuel filter mounting bracket = 70-95.4 in. lbs.
FUEL INJECTOR
Distribution pipe = 22-31 in. lbs.
DISTRIBUTOR CAP
Mount bolts = 27-46 in. lbs.
SPARK PLUG
11-16 ft. lbs.
KNOCK SENSOR
14-18 ft. lbs
MANUAL TRANSAXLE
Lower mounting bolts = 28-38 ft. lbs.
Upper mounting bolts = 50-73 ft. lbs.
Transaxle mounts = 49-69 ft. lbs.
Transaxle to block = 50-73 ft. lbs.
OXYGEN SENSOR
22-36 ft. lbs.
PARKING BRAKE CABLE
12-17 ft. lbs
SEAT BELTS
All seat belt anchors = 29-57 ft. lbs.
Seat belt retractors = 29-57 ft. lbs.
STARTER
28-38 ft. lbs.
ABS WHEEL SPEED SENSORS
14-18 ft. lbs.
POWER STEERING
Reservoir bolts = 5-7 ft. lbs.
Pulley bolt = 47-68 ft. lbs.
Pump = 28-38 ft. lbs.
STEERING KNUCKLE
Knuckle to Shock absorber = 69-86 ft. lbs.
STEERING SHAFT UNIVERSAL JOINT BOLT
13-20 ft. lbs.
TIE ROD
32-41 ft. lbs.
Discussion Starter #4 (Edited)
SUSPENSION
Automatic adjusting suspension bracket bolt = 21-31 in. lbs.
Ball joint retaining bolt = 24-32 ft. lbs.
Lower arm ball joint through bolts = 32-43 ft. lbs.
Stabilizer bracket bolts = 27-39 ft. lbs.
Stabilizer control link bolts = 32-44 ft. lbs.
Stabilizer control link nuts = 27-39 ft. lbs.
Stabilizer link bolts = 12-17 ft. lbs.
Front crossmember = 69-96 ft. lbs.
Lateral link bolts = 58-86 ft. lbs.
Rear cross member = 55-69 ft. lbs.
SHOCK ABSORBER
-FRONT
Mounting nuts = 33-46 ft. lbs.
Pinch bolts = 69-86 ft. lbs.
Piston rod nuts = 66-86 ft. lbs.
-REAR
TRAILING ARM
Trailing link front bolt = 47-68 ft. lbs.
Trailing link rear bolt = 64-86 ft. lbs.
WHEEL HUB
Front hub nut = 174-235 ft. lbs.
Rear hub nut = 130-174 ft. lbs.
THROTTLE POSITIONING SENSOR
Mounting screw = 14-21 in. lbs.
WATER PUMP
Mounting bolts = 14-18 ft. lbs.
WHEEL CYLINDER
Bleed screw = 57-78 in. lbs.
Brake line to wheel cylinder = 9-16 ft. lbs.
Brake hose to caliper = 16-22 ft. lbs.
Drum backing plate attaching bolts = 33-44 ft. lbs.
Wheel cylinder mounting bolts = 7-9 ft. lbs.
LUGNUTS
67-87 ft. lbs.
Discussion Starter #5
Exploded Views!
FRONT DISC BRAKES
REAR DISC BRAKES
REAR DRUM BRAKES
FUEL SYSTEM
MTX
PARKING BRAKE
If this is helping anyone, plz karma me or something, the more feedback i get the more i will post. thanx!
Discussion Starter #8
well there is abundant information available and to post all of it is gonna take tons of time. So pm me or post requests and ill put it in this thread and build it as needed :)
WOW great information man!!!!!!!!!! THNX!!!!!!!!!!
Nice, maybe someone can get the password and stuff for alldata so you there can be more info posted about the rest of the car, simple interface
Crankshaft Question
Hey thanks for all the input but i didn't see what i was looking for on there for some specs, maybe you can help...I was just wondering if the 1.8 or the 2.5DE crankshaft fits into the KLZE cause i have warped my ZE crankshaft. Thanks for any help.
All of the diagrams look like they come from the factory manual. All data is making this stuff they are just scanning pages from the manual. If you want a print out version find a manual on ebay and buy it. If you want it for free then yeah that will take a while. I know there are PDF's available for the 97 manual or someone could dedicate some time to grabbing all the pages from alldata and making their own 93-95 version kind of thing.
Discussion Starter #13
That IS what alldata does. It's all factory information. I was just posting some common stuff that can be helpful. If someone needs something they just ask, rather than paying for a manual. Just saying....don't hate, enjoy! :D
Who could tell me what kind of stretch is allowed for the bottom end bolts ?
In my Mx3 manual it has an indication but those bolts for the KLDE are longer.
Hello
I am currently doing a study exploring the factors associated with parking brake system failure. Could I use your parking brake diagrams to illustrate how the system is set up please?
thank you
1 - 16 of 16 Posts
