1 - 13 of 13 Posts
Mazda FPR (mine is 2.6bar without vacuum connected)
Stock Mazda fuelrail without FPR
New fuelregulator with an extra o-ring mounted (two instead of one larger)
Here is the adjustable FPR from a Ford Sierra (Sapphire) with the DOHC engine. You have to drill out or remove the small plate over the adjust-screw.
Kinda closefit isn't it?
You have to drill out the mounting holes a bit for the screws to fit the stock mazda fuelrail. Remeber to use the FORD scews because the MAZDA ones is to short.
Here it is nicely fitted
Adjustable!
Intriguing, won't let me give you any karma...
The Ford DOHC mentioned eventually became the Mondeo DOHC if I remember right, anyone seen the more common Mondeo part in person?
Get me a good place to put pics and i will bring them to you! :)
ftp-upload ;)
or just give me your e-mails
Discussion Starter · #12 ·
Jag tror du fått dem , men du kan få dem nästa ggn på msn om du påminner mig :)
YouAsk, these were the images I found, if you want you could copy the links and use them in your first post...
1 - 13 of 13 Posts
