Check this thread here in case you've not seen it.
http://www.mx6.com/forums/showthread.php?t=141286&page=1&pp=20
Basically, it's a thread on how the Protege/Protege 5 rear brake calipers will fit the 6 and even increase braklng a little as the pads a slightly larger. This could eliminate the seizing caliper problem.
Not sure what the Protege is called over here though... But if they fit, then it opens up more possibilities, as there is a big brake kit for them and it's cheaper than the ones for the MX6.
Front calipers also fit, but no difference as they use the same pads as we do.
Karma to the guy who discovered it.
