1 - 8 of 8 Posts
i noticed a gap from my altezza, and when i looked closer, the plastic male inserts had broken. I guess it is common. But have any of you come up with a fix? And i meen a better fix than super glue.
Already did that once, it didnt hold.
how rough did you make the surface? and did you cover it like paste, or did you just use it on the busted parts?
it was rough from when it busted, so i just dabbed it on the ends and stuck it together
do that, then coat the surrounding area, and remember to use more steel than hardener, at least that is what I do. It doesn't cure as fast, but seems stronger.
k, ill give it a shot. thanks
1 - 8 of 8 Posts
