1 - 14 of 14 Posts
DO any of you have the best idea to replace or gring the current cut-off in the E-spec's? I think im going to tackel this project this weekend and looking fo rsome advice. Also to get into the assembely of the head light, i bake it in the oven at 200 degrees for 10 min. Correct? then it should just pull appart? Or should i use a heat gun? Bolt has a good thread on it, but nothing specificaly about what he did to the actual cut off. I will want it to have a sharp cut-off so i cant mess with the dimensions too much. Thanks guys
Zach, i wish i had the money. But i dont. How or where can i get the "ECE" like yours? Like the first picture of the output light. I want mine to look like that. How?
Retrofit
Mine with E55
lowefx, you have to be lucky enough to find a set. I found mine a few years ago on ebay. They are getting harder to find, especially the ones where you can make the cutoff flat.
i dont want the cut off flat, i was just wondering how you made the cut off. Mine are currently RHD and now that i have HID's, i want to make it LHD. If i grind the RHD down with a grinder, then the cut off will be higher. But i wonder if anyone has welded a piece of new cut-off in there. im just trying to find the best option.
a sturdy piece of gauged stainless steel or aluminum and a laser cutter. it's the only way you're going to get it nuts on.
I didn't make the cutoff, it's stock with these types of bosch projectors. They have a lever built in where you can make the cutoff flat or raised.
How are you gonna keep that sheet metal or aluminum in there? Weld it?
with screws. if you look at the pedestals coming off of the projector glass, you'll see the bottom two screws that secure the shield in place
that they are :)
only the ECE Bosch projectors have this feature. The rest are DOT cutoffs, flat, 90*step and flat. The ECE's have the "Z" shaped cutoff.
You can also color mod projectors as well. You can bend the shield slightly forward for a nice color band at the center of the cutoff. I've done mine and has a nice purple/blue at the cutoff with a warm burgundy trailing off to the sides.
Dudes, you can make a cutoff plate with a pop can if you want. The sharper the edge the more color your going to have because its easier for light to bend around teh edge. :lol:
Check this thread.
http://www.mx6.com/forums/gallery/118706-homemade-projector-sheilds.html
If you really wanted you could try to make the step with a dremel or other precision cutting tool, but its going to be a bit tough to get it perfect.
Zach, I have always bent the shield twords the bowl more, but I suppose it all depends on the location of the focal point produced by the bowl.
Edit- however this is also moot because when you washer mod for color your spacing it out from the bowl. :lol: I must have got lucky with the hella 90mms in that thread.
If you want more color, just go with RX330, S2000 or SC430 with clear lens, modding the shield will affect your range.
1 - 14 of 14 Posts
